I have a question about boost. I have a Banks Sidewinder (wastegated), and I only see 7-8psi max and I really have to try to get that (WFO on a hill). I've already shortend the wastegate rod all the way. I know most guys see higher boost numbers with less effort. I usually only see 4-5 psi.
My Max EGT was 850 climbing a mountain in Tn going to the IDI Rally last summer. Most of the time I never see 600.
I called Banks and they said shorten the wastegate rod (did that before I called them) and turn up the fuel (did that with Ken's IP and Stage 1's in June last year).
The other issue is my boost gauge sticks alittle. It will just jump up to 2-3 psi when the turbo starts making boost. It may be innacurate, but the EGT's aren't high enough to make me think it is off by much. I think that if I were really making 10-12 psi, the EGT's would be much higher than 500-600?
What do you think? Any suggestions for more boost? Do you think I should crank up Ken's IP some more?
A "friend" of mine suggested just "unpluging the wastegate tube" and "see what happens." That sounds a little scary, but, it is sounding more and more tempting all the time.
I PM'ed Ken with this same question, but, he doesn't get on-line very often. We do you guys think?
P.S. My wife is 9 months pregnant.........I'll post pictures when she's born.
