PSD lift pump assembly
Rusgo
US
Been seeing these around a bit. Used on powerstrokes from 99 to 03.
Could be a good alternative to a facet lift pump? Guessing it has much higher potential fuel delivery.
Can find the entire assembly used all day long. Has connectors, frame mounted isolated bracket, and it looks like the same fuel fittings that we used.
Sent from my SM-G975U using Tapatalk
tjsea
Lickdale, PA
I've used them before on other psd trucks. They are very high quality and last a long time. To use it on an idi you would need a bypass style regulator to cut the pressure down though. On a psd they run 65psi which is way too high for an idi.
Rusgo
US
Yeah that's way high. Figure bypass flow would be substantial with a setup up like that. Too bad. Such a nice setup.
tjsea
Lickdale, PA
Yeah, a good bypass regulator would work great for keeping pressures in check.
@79jasper do you happen to know the micron rating on the 6.0 HFCM filter off the top of your head? I know the 6.0s used a secondary filter as well but was just curious if the primary filter would be sufficient standing alone.
Administrator Moderator
The primary in the HFCM from the frame rail is 10 Micron. The Secondary up on the engine is 4 Micron.
Kevin 007
Full-floater
Nelson BC Canada
Yeah the OEM psd pumps have been seen lasting 10,000hrs, 400,000miles. Which has me impressed. Will see if the aftermarket ones last half that.
aggiediesel01
Houston, TX
Is high bypass flow a problem? Put in a good filter and polish the fuel.
At first thought a high amount of bypass might mean that the pump would start heating up the fuel in the tank after a while of running. But then after thinking a bit more, 7.3s and 6.0s get in the same neighborhood of fuel economy so that means they use approximately equivalent amounts of fuel to do equivalent amounts of work. So, wouldn't the 6.0 pump in a 6.0 environment bypass approximately the same amount of fuel back to the tank as if the pump was used in a 7.3 IDI IDIT or DIT? Just because the HEUI needs higher initial pressure to fill the injector doesn't mean that it's putting more volume into a cylinder under similar loading as an IDI so the rest of the volume still has to go back to the tank. OBS PSD Single Shots are 95cc injectors, aren't the stock IDI pumps about similar? Aren't the hopped up idi pumps making around 120-135CC? The stock PSD Split Shot injectors are 130-140cc. So to me the PSD fuel system might work out fine for these old trucks especially if they are cheap and reliable. Figuring out how to tie in the return might be the stumbling block as that much volume pushed into the existing return might raise the return pressure enough to flood the IP or cause problems up there.
That is why you would run a dedicated return line from the regulator.
A couple here have done it. I don't recall their names.
I’m running a GSL392 in a couple trucks, it’s basically an upgraded version of the 7.3 psd pump and is commonly used in their application. It requires a high flow bypass regulator and a dedicated return so to not pressurize the return system connected to the ip. It works great and is extremely quiet. One of my customers is running two with the db4 I built.
tke395
