1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Project: The New CDD Shop Truck
Discussion in '6.9L IH & 7.3L IDI Diesels' started by Thewespaul, May 15, 2018.
  1. The_Josh_Bear
    The_Josh_Bear Full Access Member
    810
    445
    Jun 1, 2016
    Western WA
    Lift? I'm starting to think Wes is part Jedi...uses the Force to get all this work done he does.
    :rotflmao
    nostrokes and IDIBRONCO like this.
  2. IDIBRONCO
    IDIBRONCO IDIBRONCO
    5,483
    3,722
    Maybe just young. I used to do a lot of head swaps in frame when I was his age, working on these engines for a living. I never used anything other than my hands to lift them into place.
  3. Garbage_Mechan
    Garbage_Mechan Garbage Mechanic
    947
    451
    Jun 9, 2008
    Central Cal Foothills
    Ditto that!
    IDIBRONCO likes this.
  4. Thewespaul
    Thewespaul Supporting Vendor Supporting Member
    8,563
    7,393
    Jul 27, 2015
    Bulverde, Texas
    It’s all in how you hold your mouth to get everything lined up... really though, the trick is to cradle the head on your forearms, get the lower studs above the exhaust ports lined up, then tip the head onto the rest of the studs. That way you can see everything get lined up and you’re not holding the head over the studs for long trying to support all the weight and gingerly line things up. image.jpg
  5. austin92
    austin92 Full Access Member
    982
    289
    Jul 20, 2016
    Brazil. IN
    1. Most wheel bouncing off road is not wot like a launch will be. Slicks are going to grip the track better than an all terrain will in dirt.
    2. I think 800ft lbs on 28s will break more stuff than 260ft lbs on 37s
    3. My truck is identical to his and it rolled over the scales at 5600 with me in it. That’s non turbo, non intercooled, no meth, no nos. That stuff adds up.
  6. austin92
    982
    289
    Jul 20, 2016
    Brazil. IN
    Looks like the tubes are welded, assuming you’re aware the diff will spin on them? Lol
  7. Thewespaul
    8,563
    7,393
    Jul 27, 2015
    Bulverde, Texas
    Never had an issue, car went 9.3 @ 139 and weighed 3500lbs. Cars not around, driver got scared of a wheelie and put it in the wall... lots of guys put them in s10s, there’s one on YouTube that was putting four digits down through stock welded diff and axles with a 4l80e.
    Axle choice will all come down to budget. 8.8 would be the lighter than a 10.5 but sterling would be cheaper and simpler. 9 inch would be strongest and lightest but would be the most pricey. We’ll cross that bridge when we get to it LOL
  8. chillman88
    chillman88 Supporting Member Supporting Member
    3,759
    2,792
    Feb 22, 2017
    Central NY
    I'm certainly not going to argue but you must not wheel with the same knuckleheads I do LOL
  9. austin92
    982
    289
    Jul 20, 2016
    Brazil. IN
    Definitely not trying to pick any fights. Just blown away at the idea lol. After grenading a dana 35, countless 1310 u joints, and a np231 t case I learned to drive differently. Most people on Camaro forums say the 8.5 10 bolt in my 2nd gen is good for about 400hp if you’re hooking good and it’s right there in size with a 8.8. I hope you don’t break it if you choose that route though. It’d take the 8.8 up a few notches in my book lol
  10. Thewespaul
    8,563
    7,393
    Jul 27, 2015
    Bulverde, Texas
    Well nice thing about the 8.8 is they’re like 50 bucks in my area, I’m not opposed to breaking things, just as long as it’s not compromising safety. We will see how it all pans out. Right now just focusing on getting the shop truck back together. Got the engine assembled to a long block, just gotta do some pump mods, install accessories and turbo kit then I’ll be stabbing the engine.
  11. saburai
    saburai Supporting Member Supporting Member
    2,031
    853
    Mar 15, 2016
    Yeah, ya think?
    Many times over. What's an air filter? Miles of Texas dirt farm roads. Our man Wes is breaking it so we don't have to.
    Thanks for all you do Wes!
  12. Finn
    Finn Registered User
    Apr 4, 2008
    naperville Il, Dollarbay
    Don’t screw around trying to backyard engineer the head gaskets to “improve” coolant flow.
    Hundreds of hours of engineering time went into designing and developing the cooling passage size and restrictions to balance the flow path and distribution to optimize the temperature distribution of the cylinder walls and cylinder heads.
    Going in and hacking up the gasket passages without understanding why they are what they are, and not having a fully instrumented engine on a laboratory quality dynamometer test rig is a fools mission.
    Trust me. I was there when this engine was developed in Melrose Park.
  13. saburai
    2,031
    853
    Mar 15, 2016
    :popcorn
    austin92 and chillman88 like this.
  14. Thewespaul
    8,563
    7,393
    Jul 27, 2015
    Bulverde, Texas
    Well then, please explain why blocking half the coolant flow benefits the cooling systems performance.
  15. Thewespaul
    8,563
    7,393
    Jul 27, 2015
    Bulverde, Texas
    It’s not the prettiest engine, but it’s ready to be put home. (Three exhaust manifolds later) image.jpg
    Frstdiesel, chillman88 and YJMike92 like this.
Share This Page
