Well the second attempt at the fuel system went better, but I need some advice. I reinstalled the rebuilt pump and now have 15psi at the pump and it primes on its own so that part is fixed. Now I have a deadhead regulator on the engine to cut the pressure to the 7psi limit, but with the engine regulator cranked all the way I can only get 1 or 2 psi. I'm thinking it's because the carburetor regulator just isn't good for a system that still returns some pressure after the regulator. So I called fass to see if a lower pressure spring for the pump was available and just do away with the engine regulator, but the lowest was 10psi. What do you guys think with this issue?
