So made a little progress.
Painted up the drums. Just a quick rattle can.
Parts!
I got half the shocks, box of relays, injector line clamps.
Installed front hubs. Here is the repair kit from bronco graveyard.
Here's what you get.
New snap rings inner and outer. New o-ring and bolts. Not sure if the bolts are stainless but I doubt it.
So I get the first hub in lightly lubed. Went to put the cap on and discovered a problem.
See it??
Yep. Damn.
After messing around a while and making a trip to depot at closing, I ended up with a solution. I had a set of speedyouts but I had broken the small one. So I had to buy a new set. Being a cap screw it was too hard for the extractor to drill so I went at it with the tap drill size bit to get a hole started then stuck the extractor to it.
Happy dance.
And the other side. Less eventful.
That's where we are. More cleanup and assembly tomorrow. I'll probably slap the axles back in and maybe get the rear diff ready for fluid.
