I could be wrong, but iirc from my previous research, cr owns skf now.
That sucks. I had no issues at the wheels. My pain was self inflicted at the T-fitting. Because of all the brake line changes is there a chance there is 1989 wheel cylinders with 1990 brake lines or some such nonsense? I didn't think the wheel cylinders changed, but who knows.
Keep us posted.
@junk I'm real glad you said something because it caused me to go out and look at things closer this morning and sure enough you are correct. The result being that now neither line is correct. Both have the wrong size fitting at the end for the wheel cylinder.
I'm going to post on the open forum but does anyone know if there is a fitting size difference between F250 and F350 or SRW to DRW? I have my paper work on the lines but at this instant, I'm not sure what I told them it was going on. I may have told them F350 since the running gear is F350 but I'm pretty sure I bought F250 wheel cylinders. I am also pretty sure that 250 and 350 called for the same part at least in SRW.
