Well, I am in the middle of a hydroboost conversion - I am replacing the pump as it is shot. Upon closer inspection, I realized I had a hillbilly fix... The PO fanagled a GM pump into the mix... Amazing really, held by one bolt - the belt tension kept the whole works braced against the front bracket that the PS pump bracket would bolt into... I feel a bit silly for not making a closer inspection earlier - but now I can make it right...
Only problem, I am uncertain if the OEM bracket was used on the GM pump somehow... I can't seem to find a conclusive reference either, and it is questionable if the bracket I have is indeed OEM... So short of buying a third repair manual, I was hoping someone here had a clear image of the bracket...
And does anyone have the diameter of the PS pulley? That would be my next uncertainty in the conversion...
Thanks to everyone for their input...
