Power Burst
Maddogeast
New Milford CT
Took truck out 97 cc dually and it idles and revs fine as usual but say cruising 40 and not touching gas pedal it will act like im jumping on it. Fuel pressure good. What can it be. No codes.
greenskeeper
PA
So with ZERO pedal input (not holding it steady at 40mph with pedal pressure) the truck will accelerate on it's own???
Maddogeast
New Milford CT
Ok. Ill try the icp. Makes sense. Was thinking that cps would maybe give an advanced timing signal to emu. Motorcraft ICP or it doesnt matter ?
greenskeeper
PA
If you're guessing on the ICP sensor, just unplug it. It will set the SES light defaulting the PCM to a set number for oil pressure. See if the problem continues before buying a part to throw at it.
I'd bet on the TPS going wonky IMO...does it do it with the cruise set at 40mph ?
