94.5 body, idm110, mle1 pcm
7.3, zf5, 4x4
Truck will rev out in neutral; but no power to accelerate; will idle up to speed if you let it.
FORScan buzz test says injectors 5/7 high to low issue.
So I moved the 1/3 pigtail to 5/7 and vice versa; still says 5/7 issue. If the 5 pin uvch connector was the issue, then it should've followed and now said 1/3 is bad since the 5/7 connector is now on 1/3.
So I flipped the UVCH completely; and put 5/7 back where it goes and 1/3 back where it goes; so if the issue is in the harness at 5/7 then the issue should now be at 1/3 since the harness has been flipped.
Issue is still 5/7.
Means my IDM 5/7 is bad, yeah?
7.3, zf5, 4x4
Issue is still 5/7.
