Well all... I have been calling several shops asking how much cleanance we have between the piston and the head. Seems this question has not been addressed by any of the shops. At Promar I talked with John and Brian. Each piston is milled to fit. They warned me that these pistons will rock (roll over ATDC) about 12 thousands so make sure the piston has the proper cleanance or they will hit. Example. If the piston clears the top of the block by 30 thousands then add 12 thousands to that and you have 42 thousands of the piston above the block. If your head gasket is 70 thousands thick (Felpro are about 72 thousands umcompressed) you will have a clearance of 28 thousands before the piston hits the head. Diesel Direct will use 5 thousands above the deck. They mill each piston to fit also and the go the extra mile a ceramic coat the top of the milled pistons. I still want the factory specs for clearance of piston from head. The factory specs for piston above the block is 10 to 31 thousands and that was verified by our members here. Thanks. Chris at Diesel Direct told me the hard anodized tops on the Mahle pistons can easily be flycut using a 2 1/2 inch flycutter. All the anodized top is aluminum that has been traeted so it machines off fine. Looks like I will be flucutting my pistons soon. Chris also said they set up these 7.3 motors to run on 18 to 1 compression ratios. I don't feel to good about that number. I really question that.
