Reviving this back from the dead, but flex fans are only scary if you don't pay attention to what you're buying. For instance some have aluminum blades - avoid those like the plague, they will fatigue and crack around the rivets holding them to the hub. Then there is the hub itself - some fans have just one piece of steel, what you want instead is for the blades to be sandwiched between two hub plates and riveted w/ as many rivts as possible, IIRC the flex fan I put on an old hotrod of mine had 6 per blade w/ the massive ninja-throwing-star-shaped hub plates (that one also saw over 5k rpms literally on daily basis). But good luck finding such a fan in the size needed for our trucks, largest I've seen is 19" which was actually smaller than that - there are 21" fans but they are not high-revv suitable, even says so in their description. 23" flex fan, of any kind, not sure if it even exists...
