Pardon Me if I do a Girl Happy Dance Here.... OMG OMG OMG!!!!
Lockedhearts
Thank You Thank You 79Jasper and anyone else that suggested ICP to fix the issue on my truck! Changed it today and it is running like a CHAMP!!!! :D I still plan to go ahead and change the CPS since it sat so long without running and start doing the other maintenance things required. But it is running like a completely different truck!!!! :thumbsup:
i hope you used a FORD ICP!
if not, youll be getting another one soon :)
ive burned through 3 china made ICP's
i finally broke down and bought a fomoco part, and shes golden!
There is quite a difference between a ICP and a CPS. Which was changed?
Lockedhearts
I changed ICP , have a new CPS I am still feeling a slight hesitation so changing CPS this weekend . But the difference is amazing. My issue of start then die and the rough idle and hiccups while driving were fixed by the ICP
i suggest changing the CPS sooner than later.
takes 3 minutes to install... if that!
Lockedhearts
I won't have time until Sunday after church. Working rest of week and sat. , by the time I get home it is almost dark.
Put the Ole Man to work, hand him a 3/8" rachet, stubby extension and a 10mm socket. Tell him it's on the pass side next to the pulley, one bolt and a little wiggle and it's out, of course disconnect the wire.
Lockedhearts
Ba ha ha that is funny..... But I also drive it to work , which is where I am. :)
greenskeeper
PA
IPR should be next on the list....replaced mine OEM on amazon for $260
lewisstevey7
