parallel turbos
1mouse3
il
I got all the hydro lines sorted into a nice tidy package...
Just took a banjo to steam line them out the way, the bolt needed ground a hair shorter.
Also down here is better sorted with a hodgepodge of fittings.
So now a hole is about made, the drain line will get moved later.
A jic for this return is what is left for fitting.
1mouse3
il
To remove a hard to reach area, I made some cuts.
This is the area in question the welder had issues with.
1mouse3
il
Nice lego puzzle. You're going to need a few more zip ties to hold 15 lbs of boost though!
LOL:rotflmao
Well electric glue managed to get on it, so dont think is coming apart.
:rotflmao
This how it cleans up.
:sly
1mouse3
il
I asked nicely for it to cooperate with this bracket but keeps wanting to fight with this backet, so made them work together.
:backoff
Its together and how it will be.
So now have what looks like manifolds, still need to get the waste gates on them.
-Drool
1mouse3
il
Many stops at the hardware store, has got me most a set of studs and is enought that I can count oval holes.
This is the one that I blocked and shows no light passing, so this one fits flush enough.
This one that I have not blocked shows light, so this one still needs sorted.
And is them missing there turbos, they where dopped off a bit over three weeks ago to get balanced. Need them back so can plot where the waste gates are going, only going 10lb on this block.
1mouse3
il
-Drool
:sly
This is the clerance that was made on this braket.
This one did get ballenced but not torqued, that will be a issue since my inch torgue wrench only dose clockwise. Just snugging it a issue was found with the rebuild kit that I put in it, the outside diameter of bushing are too small. So need to find a part number so can see if a cummins dealer can get me one. Am told the other one did not need to get ballenced.
I ground a tapper on the divider for this one and still need to pull the other apart to do the same.
1mouse3
il
3in glass packs for the win...
:sly
tke395
