I was almost finished with paint preperation last week when I found a speck of rust at the very back of the bed below the taillight, as I picked at it, it opened up more and I found some bondo from the previous owner I assume, which would have been 10+ years ago. I was going to buy a patch panel but I really hate them because of how hard it is to keep the metal from warping when welding, and it seems like you always have to use body filler to make it look decent. I decided against the patch panel because I also wasn't really please with how the wheel arch turned out on that side anyway (took lots of filler work to make it come out good), so I decided it was either a new bed or a new bed side. I looked all over and the nearest bed was a quite a few hours away and the wife said no, I love road trips and I will usually jump at any reason to hook the trailer up and head out for a couple of days, but I don't want to make her mad (again). Well anyway, I found a bed side from a wrecked truck that was perfect, it took me a few hours to get it off the bed without destroying it and now I need to remove my bed side and attach the new side to the old bed.
My first question is, is there a better way to remove the spot welds. Do body shops really have to do crap the same way that I was. I drilled with a junky harbor freight spot weld remover for a while and it broke and made the rest of the job a true PITA. I finally, carefully used a torch to remove a few parts on the old bed that was junk anyway, to get the bed side seperated. I can't really use a torch on my good bed and The spot weld cutter won't really fit into a couple spots (I guess I will go buy another one).
Does anyone have any tips to get it all lined back up before I start welding? I thought about using 2x4's fastened in place of the tailgate to hold everything the right distance apart til I get it all welded.
Does anyone have any experience with changing bedsides? I would have rather just swapped beds but I could not find one close enough and without buying another whole truck (which the wife frowns on as well), She told me I need to sell something before I can get anything else.
