Recently I had a substantial oil leak and tracked it down to the oring that seals between the IP and the gear housing. The leak was fixed for about 2 months and now it is seeping out again though not as bad as before. I just want it not to leak so my question is: Does anyone know if there is one type of o ring that is better than another? I was very careful installing the pump and thoroughly greased the oring before installing it so that it wouldn't be scratched or even rubbed so I am confused as to why it is now leaking again.
87 F350 Crew cab 6.9 with ATS turbo
