renjaminfrankln
I dropped my truck off at a local diesel shop a few weeks ago to get an oil leak fixed. The turbo drain was leaking. They agreed this was the issue and pulled the turbo off to replace the grommet/gaskets.
I got a call from them today and the truck is back together, however it is still leaking oil from the same area. The mechanic said he thought it was the valley pan itself leaking. He said they put some oil absorbent on the drain and it did not appear to be coming from there. According to the shop owner it will "leave a spot about the size of a softball after sitting a few hours". This is actually better than it was before, so I am going to pick the truck up and drive it for a while (projects are piling up). The shop said the next step would be to pull the turbo back off, pull the intake and replace the valley pan gaskets.
Question: Is this a common area for an oil leak on these. I haven't seen anything about it. Also what needs to come off to pull the valley pan? I assume IP, injection lines, maybe turbo
Thanks
Thanks
