Goofyexponent
Mentally Unstable..
The 6.9 and 7.3 are almost the same motor...the only differences that I know of are the valvetrain geometry, the cylinder liner bore (which is why the 6.9 pistons won't drop into a 7.3 block) and the 7/16th's head bolts in the 6.9 versus the 1/2 inch bolts in the 7.3.
The idea has been tossed around to sleve a 7.3 block down to a 6.9 which gets rid of the block worm problem, and allows you to run the bigger 1/2 inch bolts or studs and run a little higher boost. However, an intercooler will help a lot in cooling that charged air. Cold dense air is what you want to build power. The more fuel you put into the cylinder means more boost....and higher EGT's.
Do you have a pyro gauge installed? 1200* is about the max you want to push it, anymore and you risk melting holes in things that shouldn't have holes in them....like pistons..
15 PSI is a lot in these things...it can be done, but it has to be done right with the right timing, studs, pump, injectors etc.
As someone said earlier, read the stickies and ask if you are unsure of anything....I ask questions on here ALLL the time...in fact I am about to ask another one in a new post.
