IHDiesel445
Hello all,
Haven't been on here in a while, but wanted to give you a heads up on a buildup I talked about a while back... I'm actually doing it.
The block, heads, crank, and rods are at the machine shop now. Here's what I'm doing:
7.3 block is being sleeved down to 6.9, piston height reduced by .050 to reduce compression to 17:1, head studs, fire rings, rods and pushrods hardened, stiffer valve springs, 75mm S400 turbo, water injection, and a pump and injectors built up (Agnem I'll be contacting you soon about a "Super" Moose pump and injectors).
My goal is 500hp... or close to it, at around 4500 rpm. A street driven sled puller is the object. I already have most of the parts (including the turbo setup), and will be custom fabricating the exhaust manifolds myself. Hope to have it running before summer is over. Just depends on how my crazy military schedule works out...
I'm trying to be the most powerful IDI on the road. Hope this piques some interest. I'll try to get photos posted soon.
Eric
Eric
