Diesel JD
Learn as much as you can from your Grandpa...nothing like hands on experience especially with something like diesels. A bad injection pump can cause all kinds of problems. As far as the alleged "G" code injectors...if they are truly remanufactured, the letter code probably doesn't matter. Hopefully they have really been remanned to "G" specs. Diesel care has had some good reports on here, but some not so good reports as well. Sand in the injectors would be really bad... could cause a lot of damage... As far as the wrist pin problem with a non turbo motor with a turbo....its possible but I doubt it. A lot of guys here have aftermarket turbos on both 6.9 and 7.3 IH motors with no problems. I'd say a 7.3 can easily take the 13psi it got early in its life...never mind the anemic 6psi its getting now. You just wouldn't want to go a whole lot higher than 13. I suggest getting the new injection pump from a local injection shop or shopping around online a bit. Diesel care has had enough negative feedback to make me wary of them just a little.
