6 Nebraska IDIs
- Joined
- May 27, 2007
- Posts
- 4,247
- Reaction score
- 15
This is a borderline 911 emergency here, but we have enough vehicles to get by so Im not posting it here.
As you can see from my ID name that we have 6 IDI Ford diesel trucks. 3 are 1983 6.9's and 3 are 7.3's.
First and most major issue is with my moms truck. Its a 1994 crew cab long box with the 7.3 factory turbo IDI engine (the one that all the Ford mechanics say Im insane about when I want parts for it). For about a year now its had minor engine vibration at 2000RPM until about 2400RPM, then it clears out (or its just spinning so fast you cant tell). We thought it was injector issues, so we bought a set of injectors (completely different story about the place we bought them from) and installed them. Now its almost worse than what it was before! I dont know if it could be timing causing this, doubt it, but we've thought for a while that we didnt get the timing right the last time. But we're at the point now that, if its rods or wrist pins, we dont even want to waste our time tearing into that cus it will all come back appart again. I vaguely remember when we first purchased this truck it would run nearly 13psi of boost at 2700RPM at full throttle. For over 2 years now its been running a MAX boost of 6psi. So we put a new turbo on it 4 months ago, didnt help.
Back to the vibration, it ran SO smooth when we first started it after these new injectors, then after taking it down the road and getting it good and warm, it started again, then got worse and worse! Just to put it out there, the new injectors had some OBVIOUS sillica sand in them from the shop we bought them from. This made me VERY upset, but we were stuck and had to use them. (Another note is, 7 of the injectors they sent us were clone G code injectors, restamps.) Im going to demand a 50% refund for all this crap. Cus for one we dont know for sure if I got all the sand cleaned out and this is causing us problem or if they arent built to G code specs correctly.
This engine only has 130,000 miles on it. Had 20,000 on a new short block when we bought it. After doing some research on the turbo engines, Im almost wondering if the shortblock that Ford installed was just a plain 7.3 and now we're having wrist pin issues or what.
HELP!
Help me with this one first, then I'll run my other issues by you guys.
Thanks, Sean
Also, if somone wants, it would be great if you could talk straight to me or my dad on the phone. Whatever works best. 402-540-7928
HELP!
Thanks, Sean
) it's fair to say they could still be the problem.
