Camarogenius
Can't find the luckey Larue mod. Find people talking about it, but nuthin on what it is, or how to do it.
Mr_Roboto said:Well the lucky mod is the same as buying a standard flywheel kit. Just without the expense of the flywheel.
Either way will leave you with transmission noise and the need to use a spring hub clutch disk.
The only other option is to get a new DMF.
sassyrel said:and--priced a smf flywheel lately--which is exactly what the luck mod does-------!!!!!!!! grab your shorts--disc is far cheaper than a flywheel--
