I am currently processing a warranty claim for a Moose Pump with a hot start issue. I personally built this pump in January, and when it left the building, it put out 4.6cc/100 of starting fuel. The minimum spec that we allow is 3.6cc/100 and that is slightly above what the factory specs which can go as low as 2.8cc/100 are. In order for it to fail to start the truck, it has had to loose almost half of its pumping efficiency at 75 shaft RPM (150 engine cranking speed).
The customer has had the pump for about 3 months. The reason that he bought a new pump from us, is that his original pump developed a hot start issue. Hmmm.... what would you be thinking? You probably remember my explanation of the hot start phenomena back in THIS POST . In dealing with this customer, we have had a detailed discussion that outlines the fact that in order for him to kill a pump in 3 months, that he has something seriously wrong with his fuel. Like a lot of people, he didn't want to believe that this could really be the case. He buys his fuel at a high volume, popular and well known fueling station, put a fresh filter on when he installed the pump, and does not feel that it could be anything other than a faulty pump. I don't blame him. Most people don't spend a lot of time thinking about this stuff, and most people are satisfied that "any NEW filter must be good enough, or they wouldn't sell them."
The truth is, that is not the case. When you buy a filter, you are making a decision, and often times that decision is based on price. Filter manufacturers never put the filter specs on the box. They should. If you were on a low salt diet, would you go into a grocery store and buy just any food? Or would you read the side of the box looking for the sodium content? Of course you would. My mom is on a low sodium diet for heart reasons, and I've seen some things in the store that when I saw the sodium content, I figured if she ate that it would hospitalize her for sure, if not outright kill her! We are all on a low micron diet, and need to be reading labels. There is an excellent discussion of micron sizes and how Hastings filters are rated at http://www.hastingsfilter.com/TechTips201403.html
The Hastings 1039SP filter that we sell for the 7.3 has a nominal micron rating of 4 microns at 50% That means only HALF the fuel is filtered to 4 micron. What's in the other half? Well, it could be 20. 97% of the time for that half of the fuel that remains. That still leaves 3% that could sneak by as something larger than 20 microns. And those ratings are REALLY GOOD! Makes you wonder what a cheaper, lower quality filter allows? Food for thought. KNOW your filtration when you buy.
