milner351
Gents,
I let a friend borrow my truck to haul a 4500lb gooseneck trailer with a combine corn head on it from the Detroit area down to KY...
Before he left he got me one new tire, had the others mounted and balanced that I had on hand, we changed the oil and filter, fuel filter, greased the chassis, gave it a general once over.
The vacuum pump locked up at 3am outside Louisville - thankfully he was close to an exit with an auto parts store - he slept in the truck, then when they opened he got a new pump and belt and a bit of antifreeze - and he was on his way again....
On the way home he mentioned that the "throw out bearing noise" got worse and "stayed on" for an hour or so... He said that pushing in the clutch did not make the noise change. He stopped a couple times to look things over and try to diagnose the noise, but couldn't find anything obvious - then he'd take off again and the noise would be gone, then come back again.... finally it went away and has not come back again since...
He's a good friend but I'm starting to reconsider letting ANYONE borrow my truck - he was in a bad spot and willing to pay for the tire and oil change supplies, so I figured it was a good idea.
Now I'm looking at paying him for the vacuum pump and belt, having to flush and fill the coolant since he used off the shelf coolant to top off the system, and I'm looking at either dropping the trans to do the clutch, or -- maybe the midship bearing in the driveshaft?
For years there has been a slight sqauking noise just when getting rolling from a stop in either 1st or R - during clutch engagement - I figured it was t/o bearing - the truck has 142k on it and as far as I know - has the OEM clutch.
What's the diagnosis for mid-ship bearing? He didn't think to put a hand on it during one of his stops to see if it was abnormally hot --I can check it for play - but not sure how else to diagnose the noise.... maybe its time for the SMFW and southbend or luk --- don't exactly have $800 burning a hole in my pocket.
