srmathers
Yes....while looking at the 3rd brake light, the door was open...so Now I need to test with door closed...will update results soon
next is dash lights
The one I put behind my heater controls does dim with the cluster just like factory all the way down till basically no light. I was curious isn't the cluster takes the same bulbs or not before I pull it again I know my warning lights take them.Yeah it's not hard. Pop the bezel off. I don't remember how but it's not hard. You'll need a torx driver. T25 maybe? 4 screws actually hold the cluster in. When you get it out the bulb holders twist and then pull out kinda like turn signal bulbs.
I'm very very interested in your results. If they do dim a bunch with the factory dimmer I'll probably buy some myself.
Post up a link to the same ones you bought too please!
