DougBoy66
This may already be common knowledge but, I had the dash apart fixing a few things and since I was in there I put some new LED lights in the gauge cluster. I had read not to use an LED for the battery light so I used a stock incandescent bulb there. Well, If you use an LED buld for the ABS dash light it will cause the brake to not function correctly and that new super bright ABS bulb will stay on any time the key is on. I changed it back and ABS light works as normal and the brake RABS is back to normal as well. Weird. This was my experience any way. I would have never thought that changing a dash light type would have caused that issue.
