pelky350
wanting to switch over to led bulbs in blinker/running/ brake lights front and rear, it says they need resistors for the flasher to work but also say you can buy a flasher that is meant to run with leds any options? The resistor takes away the whole point In drawing less power though? I like that they are brighter though and supposed to last longer, wish I could do my headlights led but I don't trust eBay with the ones they have for 9004 option for the brick nose, none actually come up for our trucks(bricknose) but if you search the prt number you can find a led headlight that "will plug in there" but who knows what they will do, wasn't too expensive maybe they are worth a try but I currently am running those higher shelf xenon bulbs and they are pretty good, not quite as bright as my led pods and 10 inch light bar though
