Knocking when cranking
renjaminfrankln
Raleigh NC
Does it try to catch at all... can you give a better description of the knocking. Any smoke coming out? How cold is it, and do the glow plugs work?
renjaminfrankln
Raleigh NC
Well if it turns over only wiring issue I guess would be cut off solenoid. Possibly glow plugs if it was cold enough.
Devin00235
Canisteo ny 14823
I’m not sure guys they just told me they got it running I guess it was something to do with the starting wires I’m not sure how because it cranked really fast
Devin00235
Canisteo ny 14823
Glow plugs were definitely an issue the motor is 1984 6.9 idi I don’t think they’ve ever been changed I’m changing them tomorrow what are the chances there all gonna be swollen
Golden Helmet
Monterey County, California
If they're the correct Motorcraft / Beru plugs, you will probably be ok. If someone has changed the plugs before and put in Autolite or anything else, you're probably not going to have a fun afternoon.
Go slow, don't be shy with the penetrating oil, and don't use anything other than Motorcraft / Beru plugs.
MtnHaul
California
Pretty much sums it up. If a plug is real tight just soak it with penetrating oil and gently try to work it loose a hair--once loose use more oil and work the plug back and forth to help distribute the oil. I had several very tight Autolite plugs to remove but in the end they all came out. This is not a "bigger hammer" type job. Patience is your pal!
olsen726
