In taking my engine apart, found that it had spun 2 rod bearings. Looked like the dealership that had put it in as a Ford authorized reman failed to seat the oil dipstick tube all the way into the block, as I found the tube secured at the valve cover but lacked about 3/4" of getting into the block. Since the PO used the truck as a service truck for his excavation business, you can imagine all crud that got down into the block.
My other problem, is when I was pulling the injectors, some of them were real hard to unscrew. At first I thought that they had seized in the head. But to my suprise, only the top half of the inj. came out. I had actually unscrewed the inj body. The tips on 3 of them have seized into the head. Not the top part that actually screws into the head but the bottom part with the copper washer.
Any ideas on getting them out. The torque it takes to unscrew them was almost as much as the head bolts, so I'm assuming threading the top part back on to try and unscrew them again won't do it. Is there access through the pre combustion chambers to tap them out, and how do you get the pre cup out?
Also, is Ken's the only source for head studs? I'm a little concerned about communication and turnaround time with them.
Any ideas on either subject would be helpful.
thanks
thanks
