Oldtowntrucks
My old pump is leaking pretty bad, time to replace it off my '93 f250 7.3 idi e40d.
Looking to purchase a reman one hopefully to save on some cost, probably from Rockauto unless their is another suggestion.
Looking at this Delphi Stanadyne reman IP (https://www.rockauto.com/en/moreinf...&jsn=1278&jsn=1278&jsn=1278&jsn=1278&jsn=1278) looks close to the same model no. as mine (DB05013) but am not sure.
There are two others from rockauto that look to be the same, but I can't quite tell for sure (especially with their limited info on the site...)
GB reman: https://www.rockauto.com/en/moreinfo.php?pk=8932724&cc=1124660&jsn=1272&jsn=1272&jsn=1272
Cardone: http://www.cardone.com/Products/Pro...04&p=rock&jsn=1273&jsn=1273&jsn=1273&jsn=1273
I would rather go with the Delphi for the price point with the GB as second if possible. Really can't find any matching OE numbers or even aftermarket numbers that match or convert.
My current old IP is a
Stanadyne:
No#: L2-DB2831-5013 - J
7336376 - 1816521C92
Any info on making sure these pumps match up? Or a/some brands to avoid? Need to get'r done very soon.
Thanks guys
Stanadyne:
Thanks guys
