IDI Rally attendees, PARTS Wishlist here!
Status
Not open for further replies.
IDIDieselJohn
0-60....eventually
Ottawa Ontario
Do you come by them things often?
I'm sure gonna keep you in mind once all my projects are done, and I get the funds to get into swapping a 4BT in my 4x4 F150!
IDIDieselJohn
0-60....eventually
Ottawa Ontario
Draw a triangle between Manotick, Greely, Osgoode and I am right in the middle.
Hmmm, three of us... not enough for formal IDI meet... not quite enough for a poker game, but close!
If you ever need to time your truck i have a Ferret pulse adapter you can use.
We'll have to meet up sometime! I'm in Orleans. I do have to time the new pump on my 6.9 van, and check the timing on my F350.
Blind Driver2
New Albany, In
There may be a chance I'll attend.
I need a complete set of Alcoas for a 2wd dually.
If anyone is interested, I can bring some dewatered and filtered WMO and WVO for $2 a gallon.
I have Euro headlights and turn signals for a '92+ for $120, only installed, not used. I changed to a different style.
I have a complete biodiesel processing plant, and about 100 gallons of WVO. Asking $1500. I'd bring it to the rally, but would need full payment in advance. I'm not hauling it out there all the way just to have to haul it back.
dieselgiant
Dieselgiant
Atmore, AL, USA
I've got a good list of auto to manual swap stuff among other things.
Good complete 2wd E40D rebuilt at 140k has 230k now, B&M towing shift kit. It had an external trans cooler and temp gauge since I've had it. Torque converter may be on its way out. Lock up is a little mushy, but holds tight. Comes with new flex plate and spacer. ($275/obo)
Two piece Drive shaft from Extended Cab long bed 2wd E40D. $50
Automatic cross member $10
Brake pedal assembly. $25
Auto trans tunnel. $10
Truck still has the E40d computer installed if you need it your welcome to pull it yourself.
I have all the pulleys and brackets for a V-Belt set up with A/C. $50 obo
3, V-belt alternators that kind of work.. $10 for all.
Like new voltage regulator. $5
Two V-belt A/C compressors with suction and discharge lines. $20 a piece/obo
Send me a Pm if your interested in anything that way I can keep track. We can work on the pricing some because I have no clue whats fair, not stupid, but clueless. I can post pics to.
Darrin Tosh
IDI Hound
Grand Rapids, Michigan
Few more items that will be able to bring:
Metal 5th wheel Tail Gate, Black. $75.00
Dash Mounted Air Filter Restriction gauges. NEW $15.00 each
Good Used Injection Pump, Just came off a running motor. $75.00
Good Oil Cooler $50.00
Complete set of Injection Lines. $40.00 a set of 8
I will get pics tomorrow,.
Status
