david85
are you sure,,you dont have a bad o ring in the coolant jacket..bolted to the left side of the block???? as thats what will happen,,if a oring goes bad,,oil will fill the rad...
He's got a point there^
If cavitation is going on, then you should be seeing some pressure building in the water jacket. Maybe enough to cause coolant to over flow out the recovery tank (sometimes in the form of foam).
