Yeah, I was making a post on the oil bundle. I just dont want to see you spend all that time and money on something that is an easier fix. Like this, I saw a guy replace an engine on a crown vic because it was bellowing smoke. After he got the new one in, it did the same thing. Two injectors were stuck open washing down the walls (probably still needed an engine but we will never know). If you crack the oil drain and no water comes out, it is probably the cavatation. Only slight right now and the ton of pressure in the cyl is causing the hole to open up and send coolant past when the piston is on the way down. Do any of the GPs look green (or whatever color a-freeze you are using)?
SWS
