I need a AC condenser! cant find one
Isaac Ristow
Somerset Wisconsin
I have a 84 F250 with the short wide radiator and factory ac. I can't find a ac condenser for the short wide radiator anywhere they did make them it came with it from the factory but was missing when I got the truck. Its different than the condenser used in any of the other 80-97 trucks. Anyone have one or have a lead on one? Id consider swapping the core support if I didn't already buy a new radiator for $500 for my core support. T
hanks
riphip
Memphis, TN.
Gasser/diesel replacement condenser should be the same. The GDP 3605C one should have all the mounting brackets.
Shadetreemechanic
Monteagle, TN
I just put a generic parallel flow condenser in my Mercedes diesel. I had to fabricate brackets, but the condenser was only $40 bucks on ebay. It was brand new and shipped pressurized so it was definitely solid.
A parallel flow condenser will work better with modern refrigerants anyway.
Short wide, was a Non-A/C truck. Or someone swapped out to a short wide. A/C on a short wide, was normally a dealer installed, or aftermarket A/C.
Does this truck have vents in the dash?
Isaac Ristow
Somerset Wisconsin
its factory ac factory wide radiator yes has vents in dash. they did make them this way just not many
Isaac Ristow
Somerset Wisconsin
what did you do for the lines? this would be a option but I'm not sure where to go to get lines made or how to identify the connections
Lance
