Camarogenius
I need to replace the hydraulic clutch assembly in the F-300. I know this because with the clutch all the way to the floor, like at a stop light or something, it will gradually bleed off and engage the clutch, and you have to put your foot under the pedal, and pull back before you pump it.
Autozone sells the complete system, pre-bled, for $300.00
Is the complete system available anywhere cheaper than that?
Should I just change the master cylinder, and then go through the nightmare of trying to bleed the stupid thing?
I'd rather just change the whole setup, but I don't wanna get up off $300 to do it.
