Josh Carmack
Well, the truck I speak of, had 320,000 on it when I bought it, it was using oil pretty good, hence the owner dumping it on me before it lost enough compression to be a pain in the ass. I have put another 55 60 on it. It is just now starting to have missing issues. I haven't the foggiest why. It could be coking, it could be worn injectors it could be compression loss. It could be a **** poor batch of fuel. Oil consumption has gone up enough for me to start dumping my cleanest fuel in it for crankcase lube in the last couple months. yeah yeah I know, I'm too cheap to buy a 20.00 gallon of oil every week. This stuff is so clean it looks ALMOST like new oil. The missing is isolated to one cylinder, no1 passenger side. I can tell it's that cylinder because the slow fuel filter leak that runs down on the manifold stays partially wet on the exhaust port for that cylinder. If I work the truck hard and run it fast it starts to smoke it off so I assume I'm getting a partial burn on that cylinder. IF I don't get called to work this week I'm going to build all those round tuits Ive been needing. One of those round tuits is to pull the injector on that cylinder and have a look inside with a bore scope, as well as swap the injector for a known good one.
