Seekers
I've decided to go with Isspro and the best price seems to be at www.egauges.com I'm thinking of going with this for the pyro http://www.egauges.com/vdo_ind.asp?Type=Pyrometer&Series=EVA-R&PN=R3607TR&Cart=1
but I've never had a pyro and will listen to any opinions pro or con. I am not sure of which of these probes it uses for the Banks sidewinder though. I know it is the Type K High Temp but am not sure if it is the 1.5" or the 2.5" as shown here
http://www.egauges.com/vdo_sgrp.asp?Subgroup=Pyrometer_Senders&Cart=1
Is this what is being used for the boost gauge? I couldn't find an actual boost gauge that only went to 15# and saw on a post that boost and manifold pressure were the same. Thought they must be using this then?
http://www.egauges.com/vdo_ind.asp?Type=Manifold_Pressure&Series=EVA-R&PN=R5611R&Cart=1
Tubing Kit?
That would then leave this one for my trans temp gauge
http://www.egauges.com/vdo_ind.asp?Type=Trans_Oil_Temp&Series=EVA-R&PN=R5659R&Cart=1
I only have to decide then if I'm going to mount them with a piller mount or on the dash. It seems like the dash mount would only block some of the hood view while the piller mount could block some traffic view any thoughts from guys that have these mounts? thanks for your thoughts and any and all input![Sweet ;Sweet ;Sweet](/styles/default/xenforo/smilies/Thumbup19.gif)
Tubing Kit?
