BigRigTech
Diesel junky
I have seen ARP fasteners spec less torque with moly lube but usually they use factory torque's with engine oil. I doubt 15ftlbs in the difference would be your problem but it is worth double checking with ARP. Studs stretch easier than bolts as you don't have the "twisting" stretch that you have with a bolt head dragging against the face of the cylinder head. I know the ARP headbolts that I used in my 357W were spec'd with less torque than stock - but that was only if you used moly lube.
