Grinding in reverse when letting clutch out - zf5
Philip1
Northeastern Nevada
this is where I’m starting to think, the trans also slaps a bit when you let out the clutch sometimes. Started making a kind of bell noise when I accelerate at low speed. Anyone tried a rock auto rebuild trans?
Have you checked your u joints? A bad u joint can make noise and slapping sounds if bad enough when sending power through the driveline
ComatoseLlama
MI
Im pretty sure this ended up being my crank / main bearings because they just blew out and locked up the motor. Will update after engine replacement.
