1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Grinding in reverse when letting clutch out - zf5
Discussion in '6.9L IH & 7.3L IDI Diesels' started by ComatoseLlama, Apr 6, 2020.
  1. ComatoseLlama
    ComatoseLlama Full Access Member
    124
    71
    Sep 27, 2019
    MI
    Hello,
    I've noticed a new peoblem on my truck, I think it started after my clutch replacement. When I let out the clutch in reverse, with the back of the truck pointed up a hill, the truck makes a terrible grinding noise. It's not a synchro grind, it's a deeper sound than that. Once revs hit above 1000-1100 the grinding stops. It sounds like my trans is ready to crap itself.
    Anyone else had this issue with their zf5?
    Thanks, CL
  2. 79jasper
    79jasper Chickenhawk
    27
    16,963
    1,706
    Oct 13, 2012
    2 wd or 4x4?
    You could be hearing the "normal" gear rollover from lugging.
    austin92 likes this.
  3. Dane Rickford
    Dane Rickford Full Access Member
    17
    191
    179
    Feb 3, 2020
    Markleeville, California
    My new 3 inch down pipe contacts the firewall and makes a grinding/humming sound when I’m in the situation you described. Do you notice it when you do heavy engine braking down a hill?
    ComatoseLlama likes this.
  4. Garbage_Mechan
    Garbage_Mechan Garbage Mechanic
    925
    447
    Jun 9, 2008
    Central Cal Foothills
    I’ll second the downpipe (or something). My 91 does it in off road or heavy trailer backing. One day when I have it apart for something else I will make more room for the down pipe.
  5. ComatoseLlama
    124
    71
    Sep 27, 2019
    MI
    Yes this was an issue for a day or so! My downpipe was also a TERRIBLE time to bend around the top right bolt. This is probably it Thanks!
    Dane Rickford likes this.
  6. IDIBRONCO
    IDIBRONCO IDIBRONCO
    5,360
    3,604
    This would be my guess as well.
  7. aggiediesel01
    aggiediesel01 Full Access Member
    268
    210
    Dec 29, 2016
    Houston, TX
    Double check your motor mounts. If they've never been replaced it's likely that the rubber bond to the metal plate has failed and allowing more movement than normal.
  8. IDIoit
    IDIoit MachinistFabricator Supporting Member
    12,645
    2,372
    I had the same issue with my ZF5.
    I cured it with a clutch rod heim mod and a firewall brace
    brick nose firewalls crack
  9. ComatoseLlama
    124
    71
    Sep 27, 2019
    MI
    I'm going to switch my truck back to ATF to see if it fixes it, I'm currently running straight 30-wt. Messing with my downpipe didn't help. Here's a video of the noise:
  10. Garbage_Mechan
    925
    447
    Jun 9, 2008
    Have an assistant apply torque to the engine in Fw and rev with the hood open and you standing to the side and observe if there is excess movement of the engine in the chassis. If so check motor mounts both the rubber for wear and the mounting to frame and engine.
  11. ComatoseLlama
    124
    71
    Sep 27, 2019
    MI
    Will do.
    New symptom:
    Today I downshifted into third around 2200rpm and it made a similar noise when letting off the clutch, clutched in and went back into 4th instead and everything was happy.
Share This Page
