Glow plug controller
tgomes
North Providence, RI
So I was cleaning the terminals on my glow plug controller today and it broke apart. So I guess it is time for a new one. Anyone find one of these things for a good deal somewhere or is there a better one I can install?
Controler or relay...two different parts of same system
smolkin
Stuck inside Mobile
Mobile, AL
Go manual and never worry about it again!
I bet the actual relay in the controller is still good and can be re-used.
tgomes
The controller behind the intake needs replacing. Is there a substitute if I go manual? I mean I was going to anyway.
For the Powerstrokes.
But I believe we may have a member or two running them also.
tgomes
It is not a controller. It's just a relay for manual operation. It'll outlast the truck.
If you search around they can be had a lot cheaper.
2rs
NorCal
Yup. I did 12 volt with manual push button years ago, 15+, and have replaced glow plugs twice since.
2rs
NorCal
Use a ford starter relay and a momentary push button with 12 volt glow plugs. Just like an old CAT. 10-15 seconds on a summer morning, 45 when it is freezing.
tgomes
Part numbers anyone!?! I just want to hear about something specific that worked. I like to be sure of something before I order it. I'm still learning quite a bit about motor and accessory functions.
