Danielwarden1412
I have a 93 Ford F-350 with a 7.3 non turbo Idi with 260xxx miles I put another tank on it with sending unit in tank. Put a new lift pump on it and I put fresh diesel in it. Went to start and it finally started after a bit of turning over. It did great it sat and ran for a hour and a half. Went to drive it and it stalled and died.. So I ordered a kit off eBay and replaced the o rings tees and return lines changed the fuel filter with a fram filter. Got that done and proceeded to fire the truck up took it a bit to fire up it smoked white smoke out of the exhaust and ran for a few minutes and then spit and sputtered and died.i also changed the o ring on the heating element on filter head. After i changed the filter I fired it up it ran a few minutes and died so I tightened the filter up a little more and it seemed to run longer than it has but still died I need help what would be the next step to do in getting her to run and stay running.
