fuel pressure test - grainger
greenskeeper
PA
Trying to build a fuel pressure tester using parts from grainger. Look correct?
Pressure Gauge, Liquid Filled Gauge Type, 0 to 100 psi
PIC GAUGES Pressure Gauge, Liquid Filled Gauge Type, 0 to 100 psi Range, 2" Dial Size
Item # 19RZ17
Your Price: $17.48 / each
Adpt,MNPT-FNPT,1/8-27,1/4-18,Reducer
EATON AEROQUIP Adpt,MNPT-FNPT,1/8-27,1/4-18,Reducer
Item # 38YN15
Your Price: $6.20 / each
Hose Assembly,hyd,1/4 ID x 45 In,1/4 NPT
EATON AEROQUIP Hose Assembly,hyd,1/4 ID x 45 In,1/4 NPT
Item # 2F501
Your Price: $47.60 / each
Adpt,FNPT-FNPT,1/4-18,Coupling
EATON AEROQUIP Adpt,FNPT-FNPT,1/4-18,Coupling
Item # 2F481
Your Price: $4.65 / each
Let me check when I get home. Hard to search riding in the back of a Bradley. Lol
Clb
Another old truck
nannyfornia
Op you making a pop tester???
Get some' 79 jasper
I wrenched on the xm1( the grandpa prototype)
Godspeed.
greenskeeper
PA
Replacing the schrader valve or using the filter restriction sensor?
I'd be using the existing plugs on the back of the fuel bowl. Probably the lower one that is after the filter.
