>>> JACK 'ER UP <<<
Go ahead and put a 2-inch body-lift under there before you go to jumping through hoops trying to find room.
The two-inch lift made everything else about my whole truck so much easier to access, plus giving two more very important inches ABOVE the engine, making it so much easier to add big air-intakes and various belt-driven accessories.
I don't see why so many are all negative about boosting the cab height a measly 2-inches; the same cabs are used on F-650s and such standing at least a foot taller than ours do.
If one didn't know there were risers under my cab-mounts, no one would even suspect.
Probably the best thing about a body-lift is it will force you to toss that rotten worn-out never-was-really-good steering-shaft and install a Borgeson or Flaming River .
The body-lift and steering-shaft will cost much less than a bunch of radiator and fan swapping, and you will have a better install and overall better truck for it.
