So I picked up a low mileage old ford with a 6.9 IDI, had to replace the valley pan (it had turned into a puddle of rust and fell down into the valley) and glow plugs and I've done two oil changes on it now. It has a strange noise coming out the air horn and from the research I've done it's likely a lifter, rod, rocker, valve spring or valve. It also smokes a lot, but both problems seem to go away if I crack the passenger side rear injector. I've replaced the injector with another one I had, but the problem hasn't changed. When I rev the motor it intermittently pops through the intake too.
Any suggestions? What tests can I do to narrow down the source of this rough running, etc.
Thanks!
https://www.youtube.com/watch?v=2wbmSSqBskE
Thanks!
