Beerthirty
I'm building a 1988 7.3 NA idi bottom end and putting it in a mid '93 truck that has a 7.3 idit e4od combo.
question...I need a flexplate to send off with the rotating assembly for balancing.
atp z344 work?
I have not removed the 7.3 idit yet to see which style flex/fly it uses and i do not have the plate from the '88.
I hear 1 pc. and 2.pc. and that late versions use a spacer when the flywheel became thinner design.. ?.
i was looking at the pioneer FRA490, 420 and then the atp 342,344 .
Good advice needed, what 7.3 NA flex plate will work with a 93-94 e4od?
atp z344 work?
