Jim73
Well, my first tow with the IDI was a fiasco!
Pulled my 22 foot travel trailer (5800 lbs) up I-15 through Vegas en route to the Grand Canyon North Rim last week. Pulling Cajon Pass northbound, noticed that the temps were coming up and the fan clutch wasn't engaging (at least I wasn't hearing the usual roar...) and she overheated.
To make a long story short, finally limped to the Canyon with no A/C useable and the heater blasting to keep coolant temps in check. Had to stop several times to cool her off - cracking the hood and running her at elevated idle revs was effective in dropping temps slowly. The fan RPM seemed to come up along with engine revs to about 1800- 2000, but it wasn't engaging with that airplane roar as revs were increased. The weird part, though, was that on the way back down after a week at 8000 feet and in cooler temperatures, the clutch began working as we dropped into moderately hot areas east of St. George, Utah. I hoped that a miracle cure had taken place (maybe some silicone had leaked INTO the right place in the viscous clutch during the stay up high?) but that hope was quickly dashed once we got down into the real hot sections of the desert. The drive home was misery - it was 114 degrees in Baker!
Before the trip, the cooling system was flushed and coolant replaced, along with SCA recharge. Around town before the trip in low 90s without the trailer, the fan clutch was engaging, so it seems like it works until you really need it, then goes on a break!
I'm assuming replacing the viscous fan drive is needed, but disturbed by the marginal cooling I seem to have. Has anybody done effective cooling system upgrades? I'm considering replacing the radiator, adding supplemental pusher fans, and so forth. Has anybody had success with these types of mods - especially anybody towing high and hot? How about adding external engine oil coolers in addition to the bundle on the block? (Yeah, I know, I'm grabbing for straws, but the high temps REALLY had me worried about the oil breaking down. Hopefully the tranny is OK, but time will tell. Might look at a fan-assisted additional trans cooler, too!)
What has worked for you guys?
Jim
Jim
