Joe Martin
7.3 isi factory turbo. While in overdrive and above 2000rpm it sounds like it has an exhaust leak. I can put it in neutral and rev it to 2500 rpm with no sound. No clue please help
Beat me to it jeremy!
I bet you'd get the same sound in 3rd gear too if you stomped on it. Neutral doesn't give you any load so any leaks will be minimal that way.7.3 isi factory turbo. While in overdrive and above 2000rpm it sounds like it has an exhaust leak. I can put it in neutral and rev it to 2500 rpm with no sound. No clue please help
