electric vacuum pump
Exekiel69
All You guys that eliminate the mechanical vacuum pump, what do You replace it with to control the vent, etc? I thought I read the take the ones out of a crownvictoria? What year?
Thank You.
LCAM-01XA
my very own hell
The Crown Vic ain't got no vacuum pump, its 4.6 gasser pulls very good vacuum on its own so no need for an additional pump. You're probably thinking of the PSD vacuum pump, that's electric on the '99-up models IIRC.
zebrabeefj40
Pepperell MA
I'm using an electric vacuum pump from the same truck ('99 and newer PSD...) I stole the hydroboost from. Working fine for a couple years now.
Nick
Exekiel69
Wow $65 is not what I call cheap. I have the same one on My 05 psd, never have a problem with it so I guess they are good for continuous duty (?)
Silver Burner
Burnin' Oil&Rubber
Beaverton, OR
I think I paid about 120 for a new belt driven pump, so 65 bucks sounds cheap to me. Wish I would have known about it then, because it was a PITA to unbolt the seized up bolts on the old one....
