Ok, so now I have a few pics.... Please excuse the crudeness of my wiring job... I couldn't find my roll of loom.
First pic, is of the pump and solenoid placement. I put them on the passenger side, where my jack used to reside. There was no other suitable place to mount them.
The solenoid is basically a shutoff valve, that will not allow water through, unless the solenoid has power. It's a safety measure.
Next pic, is the Hobbs pressure switch. I put it inline with the MAP sensor hose. That's also where my boost gauge line comes from.
The way it's wired, it is the ground for the relay. The black wire is grounded to the body.
Next pic is the jumble of wires, that will soon be loomed up and presentable. It also shows the mounting position of my high dollar water tank. I spared no expense on the tank!
I also have two 10AMP inline fuses. One from the battery line and one on the line, going to the pump and solenoid.
Final pics are of the nozzle's mounting position. I couldn't think of a better place to mount it. The spray from the nozzle is directly in the path of the charge air, out of the turbo. It should get very well-vaporized there. The only drawback, will come at fuel filter changing time. When that time comes, I plan on rotating the elbow towards the driver's side. Hopefully, that will allow me to change the filter.
The pipe I mounted the nozzle to, is out of an old ambulance. I didn't want to risk screwing it up and not be able to drive the truck.
As a side note, I went ahead and changed to the largest nozzle that I had. The smaller nozzle was used in a 4 cylinder rice burner and wasn't enough for the 444ci PSD. It made a noticeable difference! When the system kicks on, the boost goes from 7 to 11 very quickly. The EGT's are about 2-300* less and I have lots more available power. I haven't tried water/methanol yet, but plan to soon.
