J D Recovery
I need a new trans will I have to get one for a 7.3 or will a gasser one work?
I have a 93 f-350 7.3 n/a non turbo.
JD I understand how you must be feeling about now. Not happy to say the least. When you replace the transmission make sure you put a very large trans cooler on it. I run a tru-cool (forget the model number) on mine and have beat the crap out of it. As long as they stay cool they are pretty durable.
Sorry for your bad luck.
congrats.
i generally never got a year out of any of my E4DOA's in my F450's. I have a spare 2wd unit here but it's going to be a killer shipping it out there.
if you do stay with the trans, have a spare built and sitting aside. flush out the coolers good and it should last for a little while.
it's a little late now, but you needed not only the coolers in front of the radiator but also one that has it's own cooling fan also. Before I shut down my trucks, I had the aux cooler with fan mounted under the truck along with a extra spin-on trans filter.Yea when I put it in I put on the largest one advanced auto had (about 1/4 of the rad) We have had a lot of snow could spinning in the snow of caused this?
J D Recovery;422923I had trans redone at the end of may and put just less than 20 said:Wouldn't it still be under warranty then? Ya know, the whole thing about "1 year or 30k miles, whichever comes first"?
And methinks a C6 would be a rather suitable choice for you, but you may wanna have that one built up for big power before you stick it in, as the E4OD actually has stronger internals than the C6 so if that one failed there ain't no guarantee a stock C6 will last much longer. About the coolers - I run the trans fluid through my A/C condenser (no A/C refrigerant there no more, obviously), and she stays rather nice and cool all the time, but then again my engine fan is blowing full speed too so both the radiator and the condenser/cooler see plenty of airflow through them.
